1flyltz Posted March 14, 2014 Report Posted March 14, 2014 I want to turbo my ltz and am curious as to what motor turbo combo to run. I want to do series 3 but not sure if high or low compression would be better. I know the boost I plan on running will also determine that which I am thinking between 10 and 18 psi intercooled, and e85. So I should run low compression? What kit is recommended zzp z3 or z7 or cartuning? Quote
z34Phoenix Posted March 14, 2014 Report Posted March 14, 2014 good luck finding a csc kit.... read read research and read more. turbo builds are very finicky and highly custom. if you have to ask these types of questions you are not yet ready to go turbo. 10-18 psi is a wide margin.... high compression and boost are enemies... Quote
