My TGP made my trip home from work interesting. Brakes quit working while on freeway, brake light came on and I had very minimal braking power. Pump no longer engaged. The next morning(I made it home safely) brakes worked again just fine.
Is this a relay? Pressure switch? There are no leaks, and accumulator is new.
When mine became intermittent, it was the relay. I figured that out after trying 3 different pressure switches
Anti-Lock light on?
If it is pulled, I would get it immediately replaced, then onto finding out what codes the system has and go from there.
Thanks for the reply, there is no abs light on. Only brake light in dash. Today brakes seemed to work fine and the light is off. I had the entire unit out last year and had it cleaned up and inspected. I am gonna try the relays first and see what happens as I didn't replace them at the time. What scan tool is best for pulling codes on these?
