Psych0matt Posted March 9, 2014 Report Posted March 9, 2014 So, my passenger side brake light is disfunctional. I replaced the bulb when a friend told me it was out. Weird thing is that it lights up normal with running lights, and flashes with the blinker on, but doesn't light up the second filament when I hit the brakes. Is the blinker function just an interruption of the first filament? Both bulbs had both filaments intact, so I'm not sure where to go from here. Also, fuse 23 (stop lamp) is good. Quote
Psych0matt Posted March 9, 2014 Author Report Posted March 9, 2014 http://montecarloforum.com/forum/monte-carlo-repair-help-8/brake-light-issues-29072/ sounds like my stalk, after doing a little digging Quote
RobertISaar Posted March 9, 2014 Report Posted March 9, 2014 late 1st gen/1.5 gen W-body with brake light issues? turn signal switch. Quote
94 olds vert Posted March 9, 2014 Report Posted March 9, 2014 I agree. My CS sometimes has a brake light issue. Jiggle the turn signal and all is well again. Quote
Psych0matt Posted March 9, 2014 Author Report Posted March 9, 2014 Try the turn signal switch. I have the same problem with my monte right now. I jiggled the stalk and it seems to be working again. Good luck! Quote
tornado_735 Posted March 9, 2014 Report Posted March 9, 2014 Try the turn signal switch. I have the same problem with my monte right now. I jiggled the stalk and it seems to be working again. Good luck! QFT!! Quote
RobertISaar Posted March 9, 2014 Report Posted March 9, 2014 i've had the same problem off and on since....... 2005ish. sometimes, left turn signal requires pulling back slightly on the stalk as you switch it into position, otherwise loss of all rear lights. these things are seriously defective, i don't think the aftermarket ones are any better either from what i've seen. Quote
AL Posted March 10, 2014 Report Posted March 10, 2014 So, my passenger side brake light is disfunctional. I replaced the bulb when a friend told me it was out. Weird thing is that it lights up normal with running lights, and flashes with the blinker on, but doesn't light up the second filament when I hit the brakes. Is the blinker function just an interruption of the first filament? Both bulbs had both filaments intact, so I'm not sure where to go from here. Also, fuse 23 (stop lamp) is good. Try the turn signal switch. I have the same problem with my monte right now. I jiggled the stalk and it seems to be working again. Good luck! Did anyone else catch this? Quote
