284 Experts: Can this select cable be retrofit?
Currently my 284's select cable is a hook-style at the actual shifter. My question is, can this cable (the older-style, apparently mine is the newer style) be retrofit to use, or should I just sell/return it? I know there are probably others looking for this cable, which I found here:
http://www.finditparts.com/t/250/manufacturer/general-motors//products/3184044/general-motors-10111584
Part number is correct, or at least it's burned into the cable sleeve. I guess mine is the newer style, but there's not a huge amount of information available on these.
So I guess I'll just yank the old cable out and compare lengths. I figured SOMEONE has had this problem before.
