P0135, and P0306 98 Lumina 3100SFI
I would recommend removing the entire fuel rail assembly to make things easier. Yes that metal clip must be removed and a small flat screwdriver or pick works. I want to say a good injector will read about 15 Ohms but I could be wrong, I don't have me book with me ATM. Make sure you replace ALL the O-rings on the injectors as they will more than likely be stiff and could make resealing the injectors a pain if you reuse them, so don't. But they only come 4 to a pack.
IIRC a oil pump seal from a older 70's era Impala was the paper one to use and I cannot recall the regular O-ring size. Also get some permatex sealant #2 and put along the bottom of the lip at the top of the shaft once removed. Also put some engine oil on the teeth at the base of the shaft to make re-installation a little better. Hopefully your coolant fitting to your thermostat housing is the threaded kind and not the pressed in kind or you will have all kinds of fun.
Coolant fitting? I wouldn't think I would have to deal with that as long as I pull the fuel rail. Really the only coolant hoses I had to deal with was the two from the throttle body. What, do I have to mess with the hoses going to the thermostat in order to get the fuel rail out?
Excuse me, I see what your saying. The Hate is coming, while trying to get at the oil drive pump.
Edited by dodgethis
Thanks Rob, once I pop that clip, I have read how other have ohmn the injectors, and have got confused on doing it. To set me straight, Just simply checking resistance on each injector correct?
Found Shurkeys image about the oil drive pump: http://hbassociates.us/Lumina_Oil_Pump_Drive_01.JPG
yes, resistance check, depending on if you're using an auto-ranging meter or not, set it to measure ohms(not auto-ranging, set it to the 20ohm scale).
The "Spliced" plug wire bothers me.. Any chance you can upload a pic?... I shooting on a limb here, any chance you have changed the fuel filter. last time i had a random miss on my 4.6 mod motor was due to a bad fuel filter.. haha cost me 3 sets of plugs and a set of plug wires tracking that one down.
the "spliced" wire they are talking about, I have yet to figure out what they did. There visually is no difference. I think they just made up some "Bullshit". While reading some of the notes, they disconnected and reconnected a plug wire, and magically it ran better. I have ohmned both coil packs, and found they are within tolerance. ICM is fine, Primary is around 5.5kohms. The fuel filter has been changed before, probably 6 months old. I have a new one, just haven't installed it yet.
What I'm hoping on, is ohming the injectors without pulling the rail (trying to work up the nerve to actually do it), but really I just want to check to see what the resistance is, and go from there. If I find one out of spec, i will probably pull the rail, and replace all injectors, and new o-rings
Well that makes sense. Ive worked in several shops over the years and you wont believe the bullshit they come up with. So, plugs, plugs wires and coil all check out or have been proven good. Im no expert here but this really intrigues me, so im doing the best i can with what knowledge i have. Im sure these other guys know a shit ton more about gm then i do. Shit. i would bench test the injectors myself. Im really interested in what caused you these issues. good luck my friend.
On the another note, being a totally different power train, i just fixed a random miss on my buddies truck by replacing a faulty IAT sensor.
Alright, I couldn't figure out how to pull the connectors off the injector in order to check resistance. As far as pulling the rail, I have the two bolts off that hold it on. I have unscrewed the connector that incoming fuel line goes to. What do you use to disconnect the return fuel line up under the FPR? Damn I'm so close...
Holy Crap, this is too cool, got the fuel rail lifted! Will report on injector resistance. :thumbsup:
Ok, kinda bummed out. Injectors on the front of the engine are: I2 (12.2 Ohm), I4 (12.4 Ohm), I6 (12.2 Ohm). Back of the motor are: I5 (12.3 ohm) I3 (12.2 Ohm) I1 ( 12.2 Ohm). I found out the best way to disconnect the injector from the connector is Push in the metal clip, and while doing so pull the connector off. I have seen some video where some will pull the clip completely out. Im stumped I don't know, what could cause the misfire on 6 or 3. I will get new O-rings and gaskets to replace. Anyone have any thoughts?
Pulled the Oil Drive pump, They (Who ever had replaced the LIM Gaskets) used gasket maker around the edge of the pump. Tomorrow, will pick up all the gaskets from a AC Delco warehouse. Depending on the price I will pick up two new OEM injectors and hope for the best when I put it back together. The throttle body and plenum are still sitting in a Solvent bath. I did remove the sensor from the throttle body to prevent future problems.
Ok, Got the Oil Drive Pump replaced with new OEM O-ring, and a felpro gasket up under it. I also have replaced the injector O-rings. I was going mention, GM has replaced the Black and Brown O-rings with Blue O-rings. I didn't know that. Will pick up new OEM injectors at the tune of $112.00 a pop. Then I start putting her back together. Hope for the best! Or else: :uhaul:
A little bit of a update, So far this is what i have done.
New PCV (AC Delco)
Replaced engine rear O2 Sensor (AC Delco)
Cleaned and Replaced Oil Drive Pump with new O ring Gasket and a gasket up under the lip of the pump.
Cleaned Throttle Body, Throttle Position Sensor, Idle Air Temperature, and EGR
Replaced Sparkplugs from NGK TR55GP with AC Delco Rapid Fires
Replaced AC Delco Spark plugs wires with New AC Delco Wires
Had the Plenum Professionally Cleaned, Grabbed New Gaskets for it
Replaced all Injector O-rings, and replaced Injector 3 and 6, with AC Delco Injector
Replaced gasket, and rubber hose off of the throttle body
Questions:
I was trying to find just the plenum gaskets that had the red ring that went around each port, but oreiylls sold it as a kit with the EGR Gaskets, and lower Intake Gaskets at $80.00 dollars, Should I buy the kit, or will Fel Pro MS91481 suffice?
Would anyone suggest anything I should look at before I hook everything up today? I don't have any random engine shutdowns, just this random misfire. Have I covered everything?
The kit from Oreilly's is probably a top engine gaskets set. Plenum gaskets are probably the same and Ive never had an issue with the felpro gaskets. If you still have the same issue after this you might start suspecting the thing under the coil packs, which the name currently eludes me. If you had the misfire on opposing cylinders then coils or the module underneath would have been first suspects.
The thing under the Coil Pack, oh the ICM? Ignition Control Module, Rich thanks for the input, I definitely take account of that if it happens again. :thumbsup: AAAARRRISSSAARR, any thought sir? :lol:
not really..... you're following the logical order of things, i can't think of anything else you should be doing along the way yet.
Interesting, I saw one injector #6, was leaking from the top (connected to fuel rail) fixed that by pressing back into the fuel rail, however noticed Injector 3 was not firing. I was turning the engine over and see residual fuel left in the other injectors, but #3 sill looked dry. I guess its time to look at wiring diagram, and a light check. Fuses in the engine bay were good. :engfail:
False alarm, it helps when the injector loom is hooked up accordingly :dunce:
Well....... I put everything back together, all connections are accounted for. It ran a alot smoother. The random Misfire went away, however, I now have P0122 TPS/Pedal Posiion Sensor A Low, a Cylinder 1 Misfire, and P0403 EGR Flow Circuit Malfunction..... Oh and I noticed smoke coming from the back of the engine. I immediately shut down the car for fear of a fire. It didn't smell of gasoline burning, or what, but didn't want the house to burn down. Well back to the drawing board.....:bs:
Alright car is fixed :thumbsup: Basically, the penetrating oil used on the old oxygen sensor was burning off. I had mistaken it has a possible fire starting behind the car (I know, sounds crazy, It was late at night). Anyway, Fixed the EGR code, by swapping the Old out with a new EGR. I replaced the TPS, and all is working fine now. Cylinder 1 misfire went away amazingly. The car is running wonderfully now.
I remember vaguely that someone on the forum mentioned being careful with opening the throttle too high because one could damage the TPS. I noticed when I pulled the old TPS, it didn't return to its original position, which I ended up replacing.
Edited by dodgethis
