93CutlassSupreme Posted November 14, 2003 Report Posted November 14, 2003 any help you guys? i'm trying to adjust the trans linkage on a 93 Cutlass with a 3.1 and a 4T60E trans colum shift and i can't get the cable off the shift lever on top of the transaxle. there is something on the cable infront of the trans with a spring in it i don't know what that does and there is a plastic fixture holding the cable on the shift lever. Chilton's w-body repair book says the cable just snaps off the shift lever after pressing a button(?) on that spring device on the cable, but i can't find the button or take the cable off the shift lever. any help would be appreached. Quote
GP1138 Posted November 16, 2003 Report Posted November 16, 2003 Well, that selector arm is what I was using the wrench to adjust from Park (at the top) to Drive, with my good ol' wrench. Just take a flathead screwdriver, stick it between the bottom of the plastic and the arm itself, and twist the flathead screwdriver. After a bit of work, you should be able to wedge it off of the arm. When you've adjusted it, just take a pair of (big) pliers and use those to push the plastic piece back on. I fixed my console shift on my 4T60 without a Haynes manual. I've learned all I've learned from you guys and personal experimentation/experience. I'd have been lost without W-Body boards! Quote
93CutlassSupreme Posted November 16, 2003 Author Report Posted November 16, 2003 thanks it works thanks a lot Quote
