Loosing Coolant Series I
I have a 93 Regal Series I that has given me trouble since I got it. I have fixed most of the issues but i'm losing water quickly. I live in Florida so i'm using water until i get this figured out
-No external leak and I have pressure tested the system and it holds pressure
-After topping off the radiator, bleed the system and 10 minutes later I have a low coolant light flickering on and off and when i check it the radiator low again.
-Some bubbling in coolant reservior
-Slight mixing of oil and water
-Misfire gets worse when engine warms up
Any ideas what could cause this?
I'll attach a video of the bubbles coming from the radiator and coolant reservoir.
Edited by GrandRegal
