TGP runs ok, but lacking power
Did you bleed the rears by having someone hold the pedal halfway down and let the pump push the air out? The technique is different from the front
What specifically did you do when you removed the accumulator?
I de-pressurized, swapped accumulator, topped off fluid, turned on key.
I did the 30 step GM process.
