jr_96 Posted February 2, 2014 Report Posted February 2, 2014 my buick regal when i bought had the ignition switch harness problem, i replaced it and was fine well tonight i had turned on my left turn signal and my airbag light started flashing now its progressed, my brake light turns on as well as the flashing airbag light. Im a newbie and i want to know if i need to replace it again because i got it used off a pontiac grand prix. everything was fine until now. also if i have my turn signal on left or right prior to turn the ignition from off to on, theres a slight buzz that happens in the dash. please i need help with this problem, thank you to anyone that does Quote
l67ss Posted February 2, 2014 Report Posted February 2, 2014 Multifunction switch? my buick regal when i bought had the ignition switch harness problem, i replaced it and was fine well tonight i had turned on my left turn signal and my airbag light started flashing now its progressed, my brake light turns on as well as the flashing airbag light. Im a newbie and i want to know if i need to replace it again because i got it used off a pontiac grand prix. everything was fine until now. also if i have my turn signal on left or right prior to turn the ignition from off to on, theres a slight buzz that happens in the dash. please i need help with this problem, thank you to anyone that does Quote
jr_96 Posted February 2, 2014 Author Report Posted February 2, 2014 i believe its the ignition switch again, my gauges freak out and buzz when i turn the key to on position, when the car is done freaking out i start hit and go to turn on the blinker, the car shuts off and dies. so i believe it is the ignition switch yet again. Quote
