body molding/trim removal
how do i remove the trim/molding piece on the driver's door on the tgp? i know there are clips under there but how do i get them to disconnect
I removed my door cladding on my passenger's side door. There are 2 rivets on the back edge of the door that must be drilled out. And yes, there are screws along the bottom edge of the door that must be removed. The heads of the screws are on the jam side of the door at the bottom. Once the rivets and screws are removed, it's only the clips on the top side of the cladding that are holding it in place. All you have to do is slide the cladding up and out of those clips, and that should do it. Try rotating the cladding a little bit clockwise/counterclockwise to break it loose. It's not too bad. I had my door off the car when I did it, so that made it a little easier.
