Door Panel Fabric 92 Oldsmoblie
The fabric on the door panels is looking rough and I am looking for a replacement , where is the best place to buy the carpet for door panels and center console?
I removed the carpet from the center console and other things, sent it through the washing machine, then re-glued it. might want to try that first...
Actually, I didn't send it through the washing machine, soaked it in a bucket and scrubbed it with a stiff brush.
Since the carpet isn't gonna be molded, you could go to home depot and see if they will sell you some carpet or something of the sort.
Pressure wash it or use a stiff bristle deck brush with basic carpet cleaning stuff and let it dry in the sun or if indoor dry set everything up in a corner and put a fan on it. If there are burn marks or other physical damage then a junkyard would be your best bet if wanting to stick to factory items.
Thank you.... I went to the local carpet outlet and found carpet that is close but is a light gray I might dyed it black to match if there are no other options....
Search online Roy. Most places online should have something very similar. The majority of them will cut small samples and send them to you at a low price so you can match the carpet better.
