Suedechrist Posted January 22, 2014 Report Posted January 22, 2014 So i want to upgrade my brakes.. I have access to a 2006 monte carlo. Will the front and back brake brackets and calipers bolt right up and will i have to get steel brake lines? Quote
l67ss Posted January 22, 2014 Report Posted January 22, 2014 Yes they will fit. The rears are the same tho. You can use stock lines Quote
Suedechrist Posted January 22, 2014 Author Report Posted January 22, 2014 Yes they will fit. The rears are the same tho. You can use stock lines what will be a direct bolt on for the rear so i can go to a 12' rotor? Ive read tons and yes i know its mostly for looks but i do have five spoke 18's on and the stock brakes look bitch Quote
l67ss Posted January 22, 2014 Report Posted January 22, 2014 I know gxp rear brkes are bolt on not sure what parts youdneed. A big downside is youd have too much rear brake bias in the rear. If you were gonna run 12" inch rears id also run gxp fronts. Theyre 13" what will be a direct bolt on for the rear so i can go to a 12' rotor? Ive read tons and yes i know its mostly for looks but i do have five spoke 18's on and the stock brakes look bitch Quote
Suedechrist Posted January 22, 2014 Author Report Posted January 22, 2014 Oh really.. Okay thank you. Quote
The Guz Posted January 22, 2014 Report Posted January 22, 2014 If you can find GXP brakes from a grand prix you could run those. You will need the front lines as well. The rest I believe is a bolt on. If you are looking for just a front upgrade you could go with a set of dual piston calipers from that 06 monte carlo and keep the rears as is. You could also go with CTS V calipers. Seen that over on grand prix forums. Quote
Suedechrist Posted January 22, 2014 Author Report Posted January 22, 2014 Cts v calipers? Im looking for a direct bolt on. I like the idea there are direct bolt on methods apposed to dicking around .. I keep hearing 12x12 will be to grabby in the back but they are already the same size and if you notice rear calipers and pads are smaller in width than the fronts so im on the side that says it wont happen that way. So if i find a gxp i can take the calipers and brackets and bolt them directly on with new front brake lines and re use the rear? .. Then buy rotors and brake pads for the car the calipers belong to? Quote
l67ss Posted January 22, 2014 Report Posted January 22, 2014 Cts-v brakes are bolt on. 14". But you need a crazy offset front wheel. Cts v calipers? Im looking for a direct bolt on. I like the idea there are direct bolt on methods apposed to dicking around .. I keep hearing 12x12 will be to grabby in the back but they are already the same size and if you notice rear calipers and pads are smaller in width than the fronts so im on the side that says it wont happen that way. So if i find a gxp i can take the calipers and brackets and bolt them directly on with new front brake lines and re use the rear? .. Then buy rotors and brake pads for the car the calipers belong to? Quote
Suedechrist Posted January 22, 2014 Author Report Posted January 22, 2014 Cts-v brakes are bolt on. 14". But you need a crazy offset front wheel. Crazy offset wheel? I have kv5 sport rims 18" ? Will that work? Quote
l67ss Posted January 22, 2014 Report Posted January 22, 2014 They need like a 30mm offset Crazy offset wheel? I have kv5 sport rims 18" ? Will that work? Quote
Suedechrist Posted January 22, 2014 Author Report Posted January 22, 2014 They need like a 30mm offset Little bit over my head.. Do you mean the rim needs 30mm space between the hub and inner rim? Could i find that of the factory specs easy enough? Quote
Suedechrist Posted January 22, 2014 Author Report Posted January 22, 2014 They need like a 30mm offset crazy i just found it and i have a 35mm offset.. Lol.. No wonder my brakes look so tiny Quote
l67ss Posted January 22, 2014 Report Posted January 22, 2014 Have you checked drunkies big bad brake thread on grandprix forums? Its a how to thread on cts-v brakes. crazy i just found it and i have a 35mm offset.. Lol.. No wonder my brakes look so tiny Quote
The Guz Posted January 23, 2014 Report Posted January 23, 2014 This should keep you busy for a little bit. Here's a couple of threads on the GXP brakes http://www.clubgp.com/newforum/tm.asp?m=4741640&appid=&p=&mpage=1&key=&language=&tmode=&smode=&s=#4741640 http://www.clubgp.com/newforum/tm.asp?m=4666692&appid=&p=&mpage=1&key=&language=&tmode=&smode=&s=#4666692 http://www.clubgp.com/newforum/tm.asp?m=3189035&appid=&p=&mpage=1&key=&language=&tmode=&smode=&s=#3189035 http://www.clubgp.com/newforum/tm.asp?m=4173933&appid=&p=&mpage=1&key=&language=&tmode=&smode=&s=#4173933 C5 calipers http://www.clubgp.com/newforum/tm.asp?m=5420910&appid=&p=&mpage=1&key=&language=&tmode=&smode=&s=#5420910 CTS V calipers http://www.grandprixforums.net/showthread.php?t=46217 Quote
AL Posted January 23, 2014 Report Posted January 23, 2014 Just take the 06 monte car lo setup and grab the rotor, brake caliper, and the brake caliper bracket and you'll be all set, you can reuse your caliper if you want but I'd use the 06 one Quote
