another pcm question, thistime gtp
What gen 2 gps can you swap around pcms on without clearing security codes? 98-99 right? Thanks :)
I don't understand the question, both of those should be passkey II
Sooo..i should be alright using it on another car? Sorry im still kinda dumb when it comes to pcms. Thanks :)
If you just need a replacement PCM you should be alright. If you're doing something special that's another story. What exactly are you doing?
L67 swap :)
Yeah you need a 7797 PCM, honestly it doesn't matter what car is programmed into it because you should have it calibrated to set the tire size, remove emissions,..ect... and the tuner can put whatever GTP you want into it at the same time. Kind of like a home computer, it may have come with windows but when it's time to actually use it for real I load Linux.:o
