I'm ordering a new PCS this week, rough shifts. At the same time I'll be doing the DIY shift kit from our FAQ section.
It looks like the 1-2 & 3-4 Shift Solenoids are right there too, can somebody verify that from experience before I order them and find that they're buried deeper than I want to go? Also how's my parts list look?
My parts list so far is:
Medium Shift Kit:
McMaster-Carr
(2) 92415A865 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 1/2" Length, 1/4" Screw Size
(2) 92415A867 :: Zinc-Plated Steel Unthreaded Round Spacer 1/2" OD, 3/4" Length, 1/4" Screw Size
2-3 shift accumulator spring GM part number 24203977 ($8.26 on RockAuto.com)
WIX Filter Part # 58837 Includes pan gasket ($11.84 on RockAuto)
10 Quarts of Fluid
Solenoid Replacement:
ACDELCO Part # 10478146 VALVE,PRESS CONT SOL w/4-SPD AUTO TRANS ($35.89 on RockAuto)
ACDELCO Part # 24219819 VALVE,1-2,3-4 SHFT SOL w/4-SPD AUTO TRANS ($17.86 X2 = $35.72 on RockAuto)
FEL-PRO Part # TOS18723 17-bolt holes; GMC 4T65E-HD; 4 Speed ($20.89 on RockAuto)
Uh-oh, that doesn't look like the diagram I've been looking at.
If the TCC PWM Sol is in my line of fire it's days are numbered too.
