Engine / Tranny Swap
Hey guys I have a friend with a Pontiac Grand Prix GT with the 3800. His motor and tranny are both finished. He has come across a nice deal for a 2007 Pontiac Montana or Chevy Uplander motor the 3900 and tranny with all the subframe and the computer all wiring harness for $800. Engine and tranny have both 54,000 KM only. The van got hit in the back with damage in the front. Wanted to know if this will fit in his GT ? The only thing I see that is different is that with the 3900 engine it has a 6 bolt pattern, I know because I have the Montana 2007 SV6 with the 3900 and it has 6 bolts.
Hed b better off with another 3.8. You also need bcm and tcm withe harness and pcm along with a lotta wire splicing and pcm programming. B more headache than its worth.
Not to mention the drive by wire gas pedal. That swap would be costly and a ton of labor.
