l67ss Posted January 12, 2014 Report Posted January 12, 2014 So apparently 3.1 and 3.8s have dif shaped dipstick tubes. Ever since i 4t65 swapped my car ive had a leak around the filler tube thats gotten progressively worse(used 3.8 dipstick from donor and it never fit right). My question is this, i still have the tube and dipstick from the 4t60, will it fit my 4t65? Thanks Quote
White93z34 Posted January 13, 2014 Report Posted January 13, 2014 Any different shape would be to accommodate the engine that is in the car... if even that. I'd have to check a parts manual to be sure. I'd check the rubber grommet. any 4t65 dipstick should work.... 4t60 would probably even be the same. Quote
l67ss Posted January 13, 2014 Author Report Posted January 13, 2014 Yeah the prob im having is that the tube is hitting the rear manifold and not letting it seat, it fit perfect on the donor car(01 monte ss) Any different shape would be to accommodate the engine that is in the car... if even that. I'd have to check a parts manual to be sure. I'd check the rubber grommet. any 4t65 dipstick should work.... 4t60 would probably even be the same. Quote
White93z34 Posted January 13, 2014 Report Posted January 13, 2014 Put the one from your 4t60 back on. should be the same. verify to be sure though. Quote
l67ss Posted January 13, 2014 Author Report Posted January 13, 2014 Thats the plan i had just wanted to check before i did some thing stupid Thanks man Put the one from your 4t60 back on. should be the same. verify to be sure though. Quote
l67ss Posted January 13, 2014 Author Report Posted January 13, 2014 Compared the two and yeah, totally dif shape. The t60 tube does look like itll fit the t65 Quote
