gambler87 Posted January 10, 2014 Report Posted January 10, 2014 So I just got my 96 Gtp home finally. And I found some body flaws, and I was wondering how to fix them. Sent from my MB886 using Tapatalk Quote
l67ss Posted January 10, 2014 Report Posted January 10, 2014 Take them off to see the extent of the damage, paint can hide a lot. Quote
intern8tion9l Posted January 10, 2014 Report Posted January 10, 2014 If these are anything like the tgp, there is a metal arch piece that holds them on. Some of the rivets may have broken or rusted off, you won't know till you pop the flare off. But again, I dot know if the design in 95 was different Quote
Crazy K Posted January 10, 2014 Report Posted January 10, 2014 the arches are held to the car with shitty plastic fasteners. I made some custom fasteners using a grinder and bolts.... I ground the bolt heads to mimic the wedge shape of the plastic fastener and used nuts on the backside to secure them in place. I need to document what i have done and do more research. I used what I had on hand which was stainless steel, but next time I want to try using nylon nuts and bolts. Quote
gambler87 Posted January 13, 2014 Author Report Posted January 13, 2014 It has no metal piece, it looks like the flare itself has a 3/4 circle and then the clip on the body has a small circle protruding from it with a long piece off of one side of it. It looks like u just push the flare to the fender and turn the clip half turn to "lock" it in Sent from my MB886 using Tapatalk Quote
Crazy K Posted January 19, 2014 Report Posted January 19, 2014 It has no metal piece, it looks like the flare itself has a 3/4 circle and then the clip on the body has a small circle protruding from it with a long piece off of one side of it. It looks like u just push the flare to the fender and turn the clip half turn to "lock" it in Sent from my MB886 using Tapatalk Correct, same for all 94-96. I made homemade fasteners out of bolts. Had to pull the wheel well liner off to complete with lock nuts on the inside of the fender. On the rear, I was able to go through the vent slot, or in the trunk. By the gas door remains an issue due to lack of rear access. Quote
gambler87 Posted January 19, 2014 Author Report Posted January 19, 2014 Is there a way u could post a pic of the bolts and fasteners u used. I was thinking of 3m double sided taping the flare to the body and then just reclipping it onto the fender. Then if the clips turn out again the tape should at least hold the flare on Sent from my MB886 using Tapatalk Quote
rich_e777 Posted January 19, 2014 Report Posted January 19, 2014 I would not be opposed to Velcro-ing the flare back on. It sounds a little crazy and stupid but if you adhesive holds the strips to the metal and plastic why not? If you need some of the plastic clips I`ll be heading to a junkyard in a week or so and can grab a hand full. Seen duct tape on a rocker panel that didn't look as bad as it sounds so just thinking up ideas, its only crazy if it doesn't work right? Quote
gambler87 Posted January 19, 2014 Author Report Posted January 19, 2014 I would like a picture of a clip/fastener that is pulled out of the car as I do not know how they fasten the flare onto the body. Thanks Sent from my MB886 using Tapatalk Quote
rich_e777 Posted January 19, 2014 Report Posted January 19, 2014 Its on the list, don't know which day it will be though. Quote
Crazy K Posted January 25, 2014 Report Posted January 25, 2014 Is there a way u could post a pic of the bolts and fasteners u used. I was thinking of 3m double sided taping the flare to the body and then just reclipping it onto the fender. Then if the clips turn out again the tape should at least hold the flare on Sent from my MB886 using Tapatalk Ask again when it isn't below zero? I do want to make a few out of nylon bolts.... perhaps I could find my extra flare and make one for that? Quote
gambler87 Posted March 3, 2014 Author Report Posted March 3, 2014 Crazy k any chance u got a chance to get a pic of the fender clips? Sent from my MB886 using Tapatalk Quote
Crazy K Posted March 6, 2014 Report Posted March 6, 2014 I now have a loose fender flare, I will be doing the project asap... once the cold goes away and hell stops freezing over. I recall only doing my mod on the rears, not the fronts on my car... but i do need it on all clips. Quote
Mach 5 Posted March 6, 2014 Report Posted March 6, 2014 I used metal shelving clips and just riveted them on.. those plastic clips totally blow Quote
