Psych0matt Posted December 24, 2013 Report Posted December 24, 2013 So I noticed today that my car is doing something weird... As I'm driving my temp gauge will get up to around half, maybe a little over, but right where it should be basically, and then will drop decently low. Get warm again, drop again. Rinse. Repeat. I took a couple videos on the way home, same trip, I didn't think the first one took. New 180° thermostat (only because I had it laying around), radiator cap seems to be working just fine, topped off the coolant after the thermostat was put in, and heat seems to be functioning normally. I've just never seen something like this: http://s87.photobucket.com/user/Psych0matt/media/Mobile%20Uploads/IMG_0230.mp4.html http://s87.photobucket.com/user/Psych0matt/media/Mobile%20Uploads/IMG_0231.mp4.html Ignore the low oil light I just added some yesterday, but it seems when it's cold out it thinks it's low when I first start it up Quote
l67ss Posted December 24, 2013 Report Posted December 24, 2013 Id rebleed the cooling lines So I noticed today that my car is doing something weird... As I'm driving my temp gauge will get up to around half, maybe a little over, but right where it should be basically, and then will drop decently low. Get warm again, drop again. Rinse. Repeat. I took a couple videos on the way home, same trip, I didn't think the first one took. New 180° thermostat (only because I had it laying around), radiator cap seems to be working just fine, topped off the coolant after the thermostat was put in, and heat seems to be functioning normally. I've just never seen something like this: http://s87.photobucket.com/user/Psych0matt/media/Mobile%20Uploads/IMG_0230.mp4.html http://s87.photobucket.com/user/Psych0matt/media/Mobile%20Uploads/IMG_0231.mp4.html Ignore the low oil light I just added some yesterday, but it seems when it's cold out it thinks it's low when I first start it up Quote
94 olds vert Posted December 24, 2013 Report Posted December 24, 2013 Stop going up and down hills Temp sensor. I just had to replace mine in the GTP. Quote
Psych0matt Posted December 24, 2013 Author Report Posted December 24, 2013 I need to do that and the level sensor then... Hopefully that means I haven't got as hot as I've seen it... At least it otherwise seems to be functioning normally now. Quote
Psych0matt Posted December 24, 2013 Author Report Posted December 24, 2013 Oh, also no hills. Pretty much flat Quote
94 olds vert Posted December 24, 2013 Report Posted December 24, 2013 Oh I know its flat in MI. Lol Quote
RobertISaar Posted December 24, 2013 Report Posted December 24, 2013 if you had some magical way of checking the guage against what the PCM is seeing, that would be a great diagnostic step.... Quote
Psych0matt Posted December 24, 2013 Author Report Posted December 24, 2013 if you had some magical way of checking the guage against what the PCM is seeing, that would be a great diagnostic step.... Quote
tornado_735 Posted December 24, 2013 Report Posted December 24, 2013 Air in the system, rebleed. Been there a hundred times when my LQ1 leaked water for 6 months. Quote
Schurkey Posted December 24, 2013 Report Posted December 24, 2013 Did you change the temperature that the fan(s) activate at? Kinda silly to have a 180 thermostat if the cooling fan doesn't come on until 210 or somesuch. If bleeding air doesn't fix it, I'd say it's a sticking thermostat. Quote
Psych0matt Posted December 24, 2013 Author Report Posted December 24, 2013 Did you change the temperature that the fan(s) activate at? Kinda silly to have a 180 thermostat if the cooling fan doesn't come on until 210 or somesuch. I agree, but I'm poor and had this one brand new sitting around, as I said. The old one seemed to be sticking, but this one seems to be working, although I think I have air now. Quote
19Cutlass94 Posted December 24, 2013 Report Posted December 24, 2013 My truck does the same thing. Hooked up a scanner, and it never goes above 182* ( 180 themostat ) and only varies about 5-6*. Damn GM gauges. Quote
dhdolphns Posted March 24, 2014 Report Posted March 24, 2014 (edited) I know this is an old thread but in case your still looking or like me your on here searching for an answer to a simular problem I thought I would respond-------I dont know what car you have but if its a 92-96 Cutlass there is a TSB on Temp gauge not reading correct temp and cooling fans not working as well due to this issue.. I have a 95 cutlass with the 2 wire coolant temp and the 1 green wire temp gauge sensor..if you have this set up it could be the problem. heres the info I found on it http://www.justanswer.com/chevy/37jd6-95-olds-cutlass-supreme-sl-temp-gauge-gauge-goes-temp-sensor-tsb.html Edited March 24, 2014 by dhdolphns Quote
RobertISaar Posted March 24, 2014 Report Posted March 24, 2014 1-wire sensor drives only the guage, is in no way connected to the PCM or fans. Quote
Psych0matt Posted March 24, 2014 Author Report Posted March 24, 2014 It was just a losing coolant and becoming low issue. It happens when it gets too low, but never if I keep it topped off Quote
