Wiper wipes not correct [VIDEO]
Hi.
So I got a little problem with my wipers as you can see in this vid: [video=youtube;salbb09GKKQ]https://www.youtube.com/watch?v=salbb09GKKQ
Is this only an adjustment thing or is there broken something ?
When I turn the wipers to the fastest role the right wiper will wipe out of the A-pillar.
It´s pretty nerving when it rains !
Thank you.
I think you need to dis assemble something at the wiper motor area and adjust it that way. They look the same on my Cutlass and I`ve been needing to do the same fix.
mine has always done that since ive gotten it where it will go over the A pillar when its going fast. not sure how to fix it but it does the job and never falls off the windshield so im good with it. i did adjust the wiper position by loosening the bolt at the bottom of the arm and rotating when the motor was stopped, but other than that it is a very common issue you have. Two of my neighbors with the same gm wipers also have the issue.
Okay, hope I can fix it.
When it rains its really bad for me.
