skitchin Posted November 27, 2013 Report Posted November 27, 2013 Taking inventory on what I have so far for my swap. heads w/ spark plugs and bracket rockers and pushrods exhaust manifolds with o2 Upper manifold with egr and TB(62mm?) Lower manifold, stamped 99 Ignition coils Rails w/ injectors Mandatory pics below. TBH I'm not sure what's better between whats on my motor currently, what's compatible, etc. So far I know: I probably need to tap for a coolant fitting, and I'll need an egr adapter plate:shrug: Thinking I might get everything gasket matched just not sure if that's something a local shop can do or if I'll have to send it off to wot-tech or someone. Quote
skitchin Posted November 27, 2013 Author Report Posted November 27, 2013 Another shot of the TB I forgot, showing more linkagey bits Quote
jman093 Posted November 29, 2013 Report Posted November 29, 2013 Uggh, I wish my memory wasn't so terrible. I large port swapped my brother's 96 3100 Grand Prix a couple years ago, but I can't hardly remember anything about it. I definitely didn't get any sort of EGR adapter. I only remember having issues with the EGR pipe. I'm guessing I used the old EGR valve, but used the EGR pipe off the large port, because I think the connectors changed on the EGR valve. Does this sound right? Hope the project goes well. Keep us updated. Quote
