Restoring a '91 GTP 5spd, 284 replacement?
Picked up a white '91 GTP from Cali last week and am in the process of restoring it. Working through a long punch list of stuff that I can deal with, but it looks like the big one is 3rd gear has a syncro grind even after a fluid change. If I can't find another one to replace the whole thing, has anyone ever been able to swap parts from another 284 and successfully put it back together? How directly does a 282 bolt in?
Did you use the friction modified fluid? I've heard a few people say that's the way to go, and I myself have some for spring. I have the exact same problem, and I know parts are hard to find
I searched around and had to order some. It's a bit pricey, but I've heard it's well worth it. It's ac delco friction modified syncromesh. There's an old and new part number depending on where you find it, but if it says friction modified it's the same thing. One is AC Delco, on is GM something or other
There are two fluids offered by GM. Regular syncromesh, and friction modifier. You want the regular syncromesh. Its about $17 a qt.
I used friction modified and it almost completly solved all the issues my 284 was having. I can't say for sure if the regular stuff wouldn't have done the same.....
The 'liquid' that came out was just MUD. I about threw up.
