which spark plug wire types are for lumina z34?
ok im looking on ebay for some ignition/spark plug wires and im not quite sure which ones will fit the z... im not sure whether it is a 90 degree boot or not... any suggestions on fairly cheap wires? thanks.... also i just got my new u/d pulley from ffp and i noticed right off the bat since i have a system in my car even with a capacitor the volt meter is takin a hit is this bad? thanks later
You said z so im assuiming a 3.4twincam motor
if you want cheep wires go to O'rileys or Autozone they are 20bux.. and you can bring them back anytime you want when the break... usualy 7mm
IMO im running 7mm wires and work great the only problem i have had is the sockets riping out when i pullon them, im on my 3rd set. but its mostly my fault when i do it. still covered in warranty. :D free new wires yay
if you want larger wires be prepaired to spend a little extra doe. 8mm-9mm wires are a hot item
they do have 90degree boots and the other end has long electro rods that go down inside the heads. front ones are about 8inches the back ones are about a foot long. no exact measureents at this time.
I'm also curious if there is a preferred type of aftermarket spark plug wire out there that's used for 3.4's or do stock wires get good performance as is.
It depends how low your v meter is reading whethter it's bad or not, I don't know how low it can go and still be safe though ,sorry
  • 4 weeks later...
  • 4 weeks later...
I know Magnecor make a wire set for the 3.4. Aaron has it, you can see it in his sig pic as well. PM and ask where he got it.
Since I have a few spare 3.4 wire sets sitting around, I'm going to make my own set. I'm gonna buy a roll of MSD wire and reuse the stock plastic pieces so they look good.
