Hi everyone,
I have a 2004 GTP Grand Prix that has suddenly started dropping cruise intermittently. Seems to mostly happen when going downhill. I can do a resume and it will work for a bit, then go off again. Any ideas?
Thanks,
Brad
Bad relay?
Hi everyone,
Thanks,
Brad
I read that the "3rd" brake light could cause the cruise not to work, but cause it to be intermittent?
There's different contacts/switch for the cruise than the brake lights.
Every GM I've had for the last ten years has been a brake light switch causing
intermittent or inop cruise.
Got a scan tool? Check for "brake applied" (without touching the brake pedal)
