High beam switch stuck on high!
Another small issue with the 92 GP we just bought!
The high beams are on all the time as the directional lever won't click (just moves back and forth).
What may have snapped? How bad is it to get in there to replace/fix?
This happened on my 92 z34. I just went to the junkyard and found a switch that would click. Take the interior panel out from under the steering wheel and you can see the rod and switch, it's pretty easy to replace if it is broken.
here is a thread about it, some troubleshooting info , and where you can get it: http://www.w-body.com/showthread.php/45261-highbeam-switch
Edited by Drummer
