alright got a two part question here, one how do i replace my tps (throttle position sensor)? ive got a 93 old cutlass supreme 3.1 mfi...its a real bitch to get to, i can get to the top screw, but not the bottom one, its below the intake plem thing or whatever its called
also, my right blinker works but my left one stays on, like a bulb is out, so i checked all my bulbs, one was out, buy its still not blinkering or whatever like it should, i checked the fuse, rechecked the bulbs, and everything checks out fine, and no im not low on blinker fluid :lol: any help would be appreciated thanx
the turn signal problem is probably in the switch on the column. i had (and have again) that same trouble. what a frickin annoyance, driving through philly and *oops* no turn signals for you. so anyway, i'd check the switch. and then i would eat some pie and maybe take a nap or read. that should work.
deef
mmmm..... pie....
nah flasher would likely affect both of em. My flasher went a couple of months ago and my signals came on but didn't flash. both sides...it was fun manually flashing them LOL
