bluegp Posted November 12, 2003 Report Posted November 12, 2003 I remember reading somewhere that you are using a (factory?) CD changer with your factory "component" radio system. How did you get it to work? Is it merely a FM modulated player or did you modify the radio to get the signal directly into the amp? Thanks. Quote
Gearhead43 Posted November 14, 2003 Report Posted November 14, 2003 Bluegp, I'm using a 1996 Delco Electronics FM modulated 10 disc CD player with the stock ETR AM/FM Stereo/Cass/EQ factory Radio. When the Radio is tuned to a preset Freq. The CD Play thru the Radio's FM Tuner. Quote
bluegp Posted November 15, 2003 Author Report Posted November 15, 2003 Bluegp, I'm using a 1996 Delco Electronics FM modulated 10 disc CD player with the stock ETR AM/FM Stereo/Cass/EQ factory Radio. When the Radio is tuned to a preset Freq. The CD Play thru the Radio's FM Tuner. Thanks for the info. Did cars come factory with a FM modulated player? Quote
bluegp Posted November 15, 2003 Author Report Posted November 15, 2003 I decided to go along with the MP3 deck How did you mount it? Quote
Gearhead43 Posted November 17, 2003 Report Posted November 17, 2003 Bluegp, I'm using a 1996 Delco Electronics FM modulated 10 disc CD player with the stock ETR AM/FM Stereo/Cass/EQ factory Radio. When the Radio is tuned to a preset Freq. The CD Play thru the Radio's FM Tuner. Thanks for the info. Did cars come factory with a FM modulated player? The early 88-93 did. But I think GM started using plug in's to the rear of the radio units in 94 - up. I think the 96 CD Changer unit was sold as a GM add on kit which is why it came with FM modulator. Quote
