1995 olds cutlas conv power windows
L/F window pops out of track by door handle, looks like the molded on clip on the black is worn out.
that would be true. basically means you need a new sheet of glass. coupe one should work fine.
Not 100% sure of that...since the convertibles don't have the frame around the windows the coupes have, are the windows interchangeable? I'm thinking there's a plastic piece on the front of the convertible's glass that I don't recall seeing on a coupe. Mind you, I'm not completely sure, so I could be wrong.
