l67ss Posted October 20, 2013 Report Posted October 20, 2013 So i finally got my dic yesterday and found the wire codes today. What is the serial data wire used for? Thanks Quote
l67ss Posted October 20, 2013 Author Report Posted October 20, 2013 Also what wire supplies the fuel info? Thanks So i finally got my dic yesterday and found the wire codes today. What is the serial data wire used for? Thanks Quote
RobertISaar Posted October 20, 2013 Report Posted October 20, 2013 exact year you pulled it from? Quote
l67ss Posted October 20, 2013 Author Report Posted October 20, 2013 Iirc it was a 2002 gp gt 2-door exact year you pulled it from? Quote
RobertISaar Posted October 20, 2013 Report Posted October 20, 2013 well, looks like there was an 18 pin and 24 pin version, i assume you have the 24 pin version, but i'll just upload both. http://imgur.com/5X0FbUq,TGtKmI5 Quote
l67ss Posted October 20, 2013 Author Report Posted October 20, 2013 Yep 24 pin thanks man well, looks like there was an 18 pin and 24 pin version, i assume you have the 24 pin version, but i'll just upload both.http://imgur.com/5X0FbUq,TGtKmI5 Quote
AL Posted October 21, 2013 Report Posted October 21, 2013 Your first two questions answer each other, The serial data provides the fuel info, I just wired this into my 03 GP Quote
l67ss Posted October 21, 2013 Author Report Posted October 21, 2013 Ok thanks. Sooo..where do i hook it? Its going in a 97 monte. Your first two questions answer each other, The serial data provides the fuel info, I just wired this into my 03 GP Quote
AL Posted October 21, 2013 Report Posted October 21, 2013 I snagged it right behind the obdII port Quote
l67ss Posted October 21, 2013 Author Report Posted October 21, 2013 Ok thanks man. That was kinda where i was thinking it went but i wanted to make sure, itd be my luck id be wrong and and screw up a lot of crap. I snagged it right behind the obdII port Quote
