Airbag Light & Steering Wheel Controls
Airbag light started flashing 3 times at start-up and stays on. Also, steering wheel controls quit working and they do not light up.
I looked in the manual and couldn't see a fuse that controls these. Are they related? My initial thought is there is a harness/connector from the steering wheel that has come undone or is loose.
Thoughts???
Greg Davis
The airbag and SWRC wires are both run through the clockspring but are seperate. You could take the airbag off and check for continuity at the wheel and the bottom of the steering column for each wire.
