Imp558 Posted October 14, 2013 Report Posted October 14, 2013 Lost my last remote over a year ago and just scored a couple of key fobs at the wrecking yard, these instructions were dead on and I got them both working! Note: Existing keyless remotes will be erased with this procedure. Existing working remotes will have to reprogrammed also. 1. Locate the programming connector wire located in the RH trunk area. You may have to pull back right side trunk trim on trunk wall to locate the single black/white wire. 2. The programming connector wire should have one termial in the plastic connector on end of black/white wire. Ground the terminal in the connector to a nearby bolt or trunk latch. Leave connector wire connected to ground through out procedure. 3. System will now lock and unlock doors automatically to indicate programming mode has been activated. 4. Press any button on keyless remote. System will respond by locking and unlocking doors one time to indicate successful programming. 5. Repeat step 4 for to program any additonal keyless remotes including and existing keyless remotes. Do not remove ground wire between programming of keyless remotes. 6. Disconnect programming connector wire from ground to exit programming mode. 7. Test keyless remote(s). This information came from: http://www.programyourremote.com They have a lot more cars there too. Quote
Heartbeat1991 Posted October 30, 2013 Report Posted October 30, 2013 This didn't work on mine. The car won't enter programming mode. Suggestions? My trunk popper doesn't work either. I've only had the car a couple weeks. I'm still trying to work out all the bugs. Quote
