BlkndGoldCutlass Posted October 14, 2013 Report Posted October 14, 2013 So my '93 cutlass supreme 3.4l has been sitting in storage until I found the ambition to replace the heads. I went to start it the other day and hooked the charger up to it. A few seconds after I did that I heard a loud pop and smoke started coming outta the throttle body. I dont have anything thing now. No cluster movement or anything. Not sure what happened. Your opinions would be great they are always helpful. Thank you Quote
Imp558 Posted October 14, 2013 Report Posted October 14, 2013 It's likely a fusible link, located below the throttle body along the left side, inspect it visually and if one's fried, DISCONNECT THE BATTERY and cut it out, the guys at the parts store can identify it's rating by color and you may consider replacing it with a maxifuse holder until you figure out why something that big of a rating popped. Also check for wires chewed by rodents since it's been sitting for a while. Quote
l67ss Posted October 14, 2013 Report Posted October 14, 2013 A sealed maxi-fuse and sealed holder are a good idea you oughta see a fusable link when it blows its a wonder theres not more bbq cars It's likely a fusible link, located below the throttle body along the left side, inspect it visually and if one's fried, DISCONNECT THE BATTERY and cut it out, the guys at the parts store can identify it's rating by color and you may consider replacing it with a maxifuse holder until you figure out why something that big of a rating popped. Also check for wires chewed by rodents since it's been sitting for a while. Quote
BlkndGoldCutlass Posted October 15, 2013 Author Report Posted October 15, 2013 I can take a look and see if I could find that but would that actually cause smoke to come out of the throttle body and vacuum lines? Quote
Imp558 Posted October 15, 2013 Report Posted October 15, 2013 I think it just rose up that way, but if you don't have power you either popped a fusible link or something else like a battery cable connection. Anything that could have smoked up by the TB would have cost you just a fuse. You'll have to look the whole thing over for rodent damage. You may look the Mass air sensor over, that's in the neighborhood. Quote
Schurkey Posted October 16, 2013 Report Posted October 16, 2013 Two wonderful things about a fusible link: 1. They're cheap to build-into a wiring harness. 2. They withstand a considerable SHORT-TERM overload, where fuses typically don't. The insulation of a fusible link should be "fireproof", so no surprise that they don't often BBQ the car when they pop. Quote
