CW09 Posted October 13, 2013 Report Posted October 13, 2013 (edited) Any ideas how I can accomplish this? Is there an intake I can get that will fit up so I put a carburetor and distributor on it? Edited October 13, 2013 by CW09 Quote
l67ss Posted October 14, 2013 Report Posted October 14, 2013 More work than its worth imho and im a carb guy Any ideas how I can accomplish this? Is there an intake I can get that will fit up so I put a carburetor and distributor on it? Quote
Imp558 Posted October 14, 2013 Report Posted October 14, 2013 I'm all for impartially supporting things that others deem necessary even when I don't understand, but I just have to know, why exactly do you wish to do this? The ignition system alone would suck to make run. Quote
RobertISaar Posted October 14, 2013 Report Posted October 14, 2013 i don't think the series 2 block even has provisions left for a distributor. Quote
Imp558 Posted October 14, 2013 Report Posted October 14, 2013 I remember when my Eagle pissed my off enough to tear the rediculous ignition system out and put in an old point style from a 258 mail jeep with a mopar ballast resistor. Going back a couple decades and that POS car still boils my blood to think about. Quote
carkhz316 Posted October 14, 2013 Report Posted October 14, 2013 I've seen a number of 60*'s in demo derbys where guys did it, but as Robert mentioned, since the 3800 doesn't have a spot for a distributor it may be pretty tough Quote
Turbocharged400sbc Posted October 14, 2013 Report Posted October 14, 2013 you could easily adapt a carb to the top of the L67 LIM but youll still have to run the obd2 pcm or an OBD1 ECM to control the DIS ignition system unless you went and locked it out at a certain timing point with no ESC control for the ICM. it'd be a cunt....easier with a 60* motor since they still have provisions for the 2.8/3.1 dizzy Quote
Galaxie500XL Posted October 14, 2013 Report Posted October 14, 2013 Or, just find an old 231 V6 from the old days with a distributor....even the old throttle body engines would be fine, because you could put a manifold from a carbed car on it..or an aftermarket throttle body.. Quote
l67ss Posted October 15, 2013 Report Posted October 15, 2013 Wrong bellhousing and deck height Or, just find an old 231 V6 from the old days with a distributor....even the old throttle body engines would be fine, because you could put a manifold from a carbed car on it..or an aftermarket throttle body.. Quote
Imp558 Posted October 15, 2013 Report Posted October 15, 2013 you could easily adapt a carb to the top of the L67 LIM but youll still have to run the obd2 pcm or an OBD1 ECM to control the DIS ignition system unless you went and locked it out at a certain timing point with no ESC control for the ICM. it'd be a cunt....easier with a 60* motor since they still have provisions for the 2.8/3.1 dizzy I'm not so sure the Ignition needs the PCM to run, just for advance and retard or so I've always thought. If I remember correctly the ICM has the cam sensor and sends resolution signals to the PCM, but I may be incorrect. X2 It'd be a cunt and never run quite right either way. Quote
RobertISaar Posted October 15, 2013 Report Posted October 15, 2013 the ICMs used on 3800s(or 60V6 for the most part) do not need a PCM attached to function. however, they'll be locked to about 10* of timing and will run like crap. Quote
Turbocharged400sbc Posted October 15, 2013 Report Posted October 15, 2013 as i said, it will work just be locked out due to no ESC signal from the PCM (electronic spark control) Quote
RobertISaar Posted October 15, 2013 Report Posted October 15, 2013 perhaps you mean EST? ESC would be the knock sensor signal. Quote
Turbocharged400sbc Posted October 15, 2013 Report Posted October 15, 2013 i believe EST was the old HEI generation ignition timing control term...shit some years the timing control is just known as IC (ignition control) i may have said ESC as i was working on a ford the other day, who knows. fuck J terminology lol with the obd2 pcm the EST/ESC/EBTCM signals are all linked unlike the obd1/1.5 Quote
