pshojo Posted October 6, 2013 Report Posted October 6, 2013 Ok, I am looking into the Red Prestolite wires. I see that the 116049 shows to be for 1990-1993. Why won't the 1993 set work on the 1995? From what I can see the 1996 model moved the ignition coil to the top. The 1995 still is under the exhaust manifold. So the 116049 shows to be for the 1990-1993, 116055 is for 1996, 116055 is for 1994-1995? The reason I ask is knowing before I buy, especially because the 1993 seems a lot cheaper... Quote
White93z34 Posted October 6, 2013 Report Posted October 6, 2013 what engine are we talking about? Quote
RobertISaar Posted October 6, 2013 Report Posted October 6, 2013 has to be LQ1 with that description. i don't know why 91-93 and 94-95 would be different.....? the same thing happens with wiresets for the 3100s, they'll just randomly stop at a certain year, even though nothing actually changed. Quote
pshojo Posted October 6, 2013 Author Report Posted October 6, 2013 I'm really bad at putting all details in. Quote
pshojo Posted October 6, 2013 Author Report Posted October 6, 2013 There is set for 1990-1993 on eBay for $16. I was really tempted to get these while they are little cheaper if they would work. Could the depth be different, as far as how far they fit into valve covers? Or I should be ok with the 1993 set? Quote
ss427 Posted October 7, 2013 Report Posted October 7, 2013 I'm pretty sure the 91-93 wires were routed differently and the rear three are considerably longer in length than the 94-95 ones. They will work just fine on a 94-95 engine and as long as you route them properly you shouldn't have any excess wire around the coil packs. Quote
pshojo Posted June 12, 2014 Author Report Posted June 12, 2014 So are you saying the wires in front or rear are longer? If they are longer in the rear for 91-93 I will buy set. Since those still come in red. Quote
Nas Escobar Posted June 13, 2014 Report Posted June 13, 2014 From what I read, he said the back 3 cylinders (the ones by the firewall) had longer cables, but nothing too significant to warrant you getting the 94-95 ones. Quote
ss427 Posted June 13, 2014 Report Posted June 13, 2014 I just got a set of prestolites a few weeks ago thinking they were delcos, as they were in a delco box. I can measure them for comparison if you would like. Quote
