I have a 87 olds cutlass supreme. I have a 307 in it from a 1982 buick riveria that recently went bad. My question is will a 305 mount up with no other modifications. or would it be better to just redo the bareings in the 307. I am looking for the easiest solution. any help or advice would be great. Thanks.
Youll need diff motor mounts if you have a 3-speed transmission wount bolt up bout if you have overdrive it will
No prob i know g-bodies inside and out had a bunch of them currently hav an 86 cutlass thas gettin a 454 :)
Yeah it is just a 3spd, no overdrive. Thanks for your in put.
I think you have a different bellhousing. Unless I miss my guess the 307 should have a BOP pattern. The BOP dips down between the 2 top bolts, and the Chevrolet peaks up.
Not to mention re-routing wire harness due to relocated accessories, and starter motor on opposite side of engine. Potentially different throttle cable. Different exhaust depending on which manifolds/headers are used. No promises at all on computer programming.
That's WAY too much work to install a 305. Almost too much work to install a C-350.
I think a 231 would be a pretty easy swap, If you found a donor vehicle To pull the harnesses And stuff out of
NO!!! It would fit but it is a pure crap engine. Pure bolt in, no harness needed, just extend 12v distributer lead, and extend fuel line.
Th350 tranny is a bolt in swap throttle cable and bracket and carb swap over and the starter wiring is easy to extend programming will work but you are right on exhaust
That's the predecessor to the L36 and L67, They were descent power and tough. I had a couple of those in the day.
Had an 81 cutlass calais with one 43k on the odometer no balls and crapped out 62k oil pressure and timing issues swapped in a 403 ran like a top till it was stolen at 185k btw very little is
shared between 231 and l67, displacement balance shaft and thats about it. They even have the same deck heighth
