digital speedometer question
Would a digital speedometer from say a 94 regal be able to be wired in and work correctly in a 97 monte carlo? Thanks
why would you possibly want to make a squared off cluster work in a car with a very curved dash?
if it's for the digital speed, there were police luminas that used a modified cluster that had a digital speed and odometer readout.
Hens teeth :) was gonna build a hybrid cluster
huh?
so..... that had a 88-91 CS digi UB3 grafted into the cluster carrier of a 95-97 CS, which was then placed into a 90ish GP?
:willy_nilly:
soo... That begs the question... Would/could a UB3 fit into a gen1 gp? I've always missed mine
red plastic/vinly sheet would do it...... though light output would be noticably lower. certainly doesn't have a replacement VFD, the cost of that would be stupid-high for a one-off display.
I would actually rather everything light up the chevy/olds blue, but changing out everything in the GTP would take forever. If I did it I wouldn't be as worried about color
The few times i found a lumina digital for sale they wanted $400+ i can get a 94 regal speedo for like 10 bucks
I may be completely wrong buy I thought the last year the regals got a digital cluster was 91.
I've been trying to find one to put in my 93 regal.
Sent from my iPhone using Tapatalk
Can get you one cheap :)
the tach on the digital clusters is driven over the datastream, just like on the cutlass supreme digital UB3, so unless you want a dead tach, you'll need to work something out for that.
Found a curved dash first gen w cutlass with a digital cluster think it was a 95 anyway how bout mamin that cluster work in my monte?
that doesn't exist from the factory. the 95-97 cutlass supremes got a dash/cluster that is more or less directly compatible with the 94-96 grand prixs (the the regals fit in there somewhere, but i don't know if 94 or 95 started them).
in any case, that doesn't sound like a factory cluster.
Ill try to get a pic and some more info :)
Ended up bein a 95-96 regal sedan soo...same question can it be made to work in my 97 monte :)
1995-96 Regal didn't get a digital cluster either? 1988-92(I think) perhaps?
Its a curved dash 1st gen regal
Workin on it prolly b monday before i can get a pic tho i has no gas :( damn subway anyway my car is and will b the result of watching too much nightrider an mad max growin up :)
Wow! You HAVE to get pics of this!
Hah! I was wanting to put an Astro digital cluster in my GMC Sierra but no tach, so I will stick with the 454SS tach cluster that I got.
Mebbe run an aftermarket digi tach :)
I just don't do aftermarket anything. I use GM parts whenever possible. Even my stereo is stock but modded so I can plug in my ipod.
