1st and 2nd Gen Radiators
Can anyone verify that 1st and 2nd gen radiators are the same, non LQ1 or anything weird like that.
For example, the Oreilly Auto Parts website says a 1993 Cutlass Supreme LH0 and 1997 Grand Prix L36 use the same radiator.
Thank you.
They all interchange easy enough (aside from the 3.5 intrigue) best one to get is from an lq1 car, they have roughly a 1" core depending on car and engine you mite hav swap lower hose to line up perfectly hope this helps :)
They are wrong.
A ----------
CUTLASS 91 6-191 (3.1L), w/o eng oil cooler
CUTLASS 92-93 6-191 (3.1L), 1" thick
GRAND PRIX 89 1" thick, AT oil cooler in right tank
GRAND PRIX 92-93 w/o eng oil cooler; w/o low coolant warning sensor; 1" thick
LUMINA CAR 91-93 6-191 (3.1L), 1" thick
REGAL 91 6-191 (3.1L), 1" thick, AT oil cooler in right tank
REGAL 92-93 6-191 (3.1L)
B ----------
CUTLASS 91 6-191 (3.1L), w/eng oil cooler
CUTLASS 91-93 6-207 (3.4L), w/eng oil cooler
CUTLASS 92-93 6-191 (3.1L), 1-3/8" thick, w/eng oil cooler
GRAND PRIX 91 6-191 (3.1L), w/eng oil cooler
GRAND PRIX 91 6-207 (3.4L), w/eng oil cooler
GRAND PRIX 92-93 w/eng oil cooler
LUMINA CAR 91-93 6-191 (3.1L), 1-3/8" thick, w/eng oil cooler
LUMINA CAR 91-93 6-207 (3.4L), w/eng oil cooler
REGAL 90-93 6-231 (3.8L)
|B| fits |A|; but has greater cooling capacity & plug unused eng. oil cooler fittings.
Hollander isn't always right.
No, but my copy seems to be more correct than most for some reason. Mine shows that the blower motor to my van is 1990-96 U van only, the junkyard tells me that Cadillac Eldorado fits and it's way different.
Thank you.
I understand there are some cooling capacity differences, but it looks like they physically interchange. Now I don't have to buy a radiator. :dance:
I recall being told this interchange exists, though you may have to change the fans and radiator hold downs. I have been meaning to find out if I can substitute 94+ LQ1 radiators into earlier cars....
Through my jy research ;) should b bolt in :)
If you ever do need a radiator from O'reilly, ask them to price match 1-800-radiator. That's their supplier.
  • 2 weeks later...
I have an 89 GP radiator in my 96, the fitting for the tranny cooler were wrong but the radiator seemed thicker than my leaky stock one.
