Marcus18 Posted November 10, 2003 Report Posted November 10, 2003 I went to smokemup.com and used the edrag simulator I entered in my data and it came close to my actual times(14's). I changed the stall to 2800 and it lowered my times into the 13's do you think it would help much? seems with good tires a lsd and that stall it would do pretty well. marcus Quote
The Burning Rom Posted November 11, 2003 Report Posted November 11, 2003 I seem to remember someone posting on one of the TGP forums that moving to a different stall converter hurt performance more than it helped. :shock: Quote
dykz34 Posted November 11, 2003 Report Posted November 11, 2003 I would think you wouldnt need one unless you got a BIG ASS turbo??? The 3.1/T25 has good lowend TQ stock, doesnt it? Ive never ridden in a TGP, but Ive heard they can smoke em up. Quote
Aaron Posted November 11, 2003 Report Posted November 11, 2003 lukes tgp launched like no other, spooling instantly. Quote
Chris A Posted November 11, 2003 Report Posted November 11, 2003 I wouldn't recommend it. I had trouble with a trans builder once getting the right FL9B converter and one had a higher stall and one had a lower stall. The higher stall one was definitely slower because the turbo was already spooled. The only reason to go to a higher stall is if you have a turbo sized that would need it, which would be a really big turbo. Otherwise the engine does not need the stall since most cams you will use for a turbo don't have a lot of overlap neccesitating the need for stall, and the stock turbo sizing doesn't need any more stall either. There have been real time experiments and higher stall coverters dropped times off of the 1/4. Quote
1badtgp Posted November 13, 2003 Report Posted November 13, 2003 The TGP has KILLER low end torque due to the tiny turbo. As a matter of fact, the STOCK turbo from my DSM was bigger, and it was on a 2.0 with NO lag. I would say the need for a high-stall TC would be very little, unless you have a seriously built engine. Quote
