Firen81 Posted September 8, 2013 Report Posted September 8, 2013 So here I am again after changing coils twice, and my car died. So this time, I changed all the coils with a full set of AC delco coils, Instead of the 3 BDW ones from the last awap and the car still dies. Hit the bottom coil with a hammer and some wood, car comes back. There is fuel pressure, no codes, nothing. Im stuck. Ideas? Quote
l67ss Posted September 9, 2013 Report Posted September 9, 2013 Might b ur harnesss i had bad connection on my pcm fuse box on my 97 ls So here I am again after changing coils twice, and my car died. So this time, I changed all the coils with a full set of AC delco coils, Instead of the 3 BDW ones from the last awap and the car still dies. Hit the bottom coil with a hammer and some wood, car comes back. There is fuel pressure, no codes, nothing. Im stuck. Ideas? Quote
Galaxie500XL Posted September 10, 2013 Report Posted September 10, 2013 I was going to suggest a possibly bad crank sensor..but you mentioned hitting the coil "brought it back"...I'd be suspicious of the ignition control module. Quote
