Galaxie500XL Posted August 29, 2013 Report Posted August 29, 2013 I'm sure this has been asked before, but I'm not having any luck finding what I'm looking for... I found a '95 Regal with the 6-way passenger's seat track, and want to install it on the passenger's side of my car for the wife...the wiring is dead-nuts simple, but I need to pull the existing manual track off of my Cutlass seat, and install the Regal track without destroying the Cutlass seat. Looks to me like it's as simple as peeling back the leather skin, and unbolting the track from the Regal seat...is it really that simple, or are there other things I need to know before doing this? Quote
White93z34 Posted August 29, 2013 Report Posted August 29, 2013 gosh, its been awhile since I messed with 1g power seat tracks. Its possible, I'm just talking out of experience with driver seats, should be the same though. I am quite sure that the power seat tracks and bottom of the seat are one in the same, as in cannot be separated without a bunch of work. Basically remove the tracks from your passenger seat, then there should be a couple bars holding the material to the metal seat bottom, remove those, remove all the plastic trim, unbolt the seatback from the back of the seat, and transfer all these parts to the power seat bottom. Quote
Galaxie500XL Posted August 29, 2013 Author Report Posted August 29, 2013 That's pretty much what I was thinking...it should be nice having the power seat on the passenger's side, she says when she rides for awhile, the seat gets uncomfortable for her...the only bad part, the seat trim is red, so I'm going to have to paint it black. Thanks! gosh, its been awhile since I messed with 1g power seat tracks. Its possible, I'm just talking out of experience with driver seats, should be the same though. I am quite sure that the power seat tracks and bottom of the seat are one in the same, as in cannot be separated without a bunch of work. Basically remove the tracks from your passenger seat, then there should be a couple bars holding the material to the metal seat bottom, remove those, remove all the plastic trim, unbolt the seatback from the back of the seat, and transfer all these parts to the power seat bottom. Quote
AL Posted August 29, 2013 Report Posted August 29, 2013 Too bad you arent closer or else I would do it for you Quote
Galaxie500XL Posted August 29, 2013 Author Report Posted August 29, 2013 That's very thoughtful of you AL...thanks, I appreciate the thought. Too bad you arent closer or else I would do it for you Quote
AL Posted August 29, 2013 Report Posted August 29, 2013 I know second gen seats like the back of my hand, but first gen seats would probably be very similar... If you can pull up my thread of doing the dual heated seat conversion, I bet it may help with what you are going to encounter during your seat track swap Quote
l67ss Posted August 29, 2013 Report Posted August 29, 2013 Iirc the bolt patterns are symetrical Quote
Galaxie500XL Posted August 30, 2013 Author Report Posted August 30, 2013 (edited) I saw that link...looks like the second gen seats are made a bit differently. I had hoped it would be like when I swapped the front seats in my old LeBaron, four bolts, and the track comes off of the seat...but NOOOOO.... I know second gen seats like the back of my hand, but first gen seats would probably be very similar... If you can pull up my thread of doing the dual heated seat conversion, I bet it may help with what you are going to encounter during your seat track swap Edited August 30, 2013 by Galaxie500XL Quote
l67ss Posted August 31, 2013 Report Posted August 31, 2013 Thats EXACTLY how first gen seats are I saw that link...looks like the second gen seats are made a bit differently. I had hoped it would be like when I swapped the front seats in my old LeBaron, four bolts, and the track comes off of the seat...but NOOOOO.... Quote
Galaxie500XL Posted August 31, 2013 Author Report Posted August 31, 2013 Hmmm...the bolt heads are turned around on the INSIDE, between the track, and the seat...it's really that simple? Thats EXACTLY how first gen seats are Quote
l67ss Posted August 31, 2013 Report Posted August 31, 2013 That would make it a lot easier Ratcheting wrench would be best Quote
Galaxie500XL Posted September 1, 2013 Author Report Posted September 1, 2013 It was a little more complex than "4 bolts", but not bad...the recline mechanism had to be swapped from my old frame, the Regal was a 4-door, and the recline didn't allow for the seat to fold forward to help rear passengers.. Everything bolted up great, and looks like a factory install. Wiring was spliced from behind the floor connector for the power driver's seat, then run under the carpeting and console just behind the shifter, then exiting the carpet next to the airbag module under the passenger's seat. Quote
AL Posted September 1, 2013 Report Posted September 1, 2013 Sounds like how i run my heated seat wiring Quote
Elias1552 Posted February 24, 2014 Report Posted February 24, 2014 What about the back seat? I'm trying to do the same thing,But all the way around. They look about the same length, and if you say the front are bolt and splice am I correct to assume they are too? Quote
ManicMechanic Posted February 25, 2014 Report Posted February 25, 2014 I was going to do this mod when I had my Cutlass. Quote
Nas Escobar Posted February 25, 2014 Report Posted February 25, 2014 Since this thread showed back up, instead of making a new one I'll just ask... can you use the driver's side track on the passenger's side, or is it proprietary? Quote
