l67ss Posted August 21, 2013 Report Posted August 21, 2013 Wondering if a 4t65e from a 99 olds intrigue 3.5 will interchange with a 98 monte z34 4t65e 3.8 Quote
RZB1992 Posted August 22, 2013 Report Posted August 22, 2013 Not positive if they will interchange or not, but I do know that the 1999 model year Intrigues with the 3.5 had two different transmissions - one with a 3.05 ratio (RPO Code F83), and one with a 3.29 gear ratio (RPO Code FR9). Make sure you know which you're getting when you get one. Quote
RobertISaar Posted August 22, 2013 Report Posted August 22, 2013 it will all bolt up no problem, same bellhousing pattern between them. working 100% as intended.... maybe. with the 3.29 version, pretty good chance of it being acceptable, to say the least, especially without any calibration tweaking. Quote
l67ss Posted August 23, 2013 Author Report Posted August 23, 2013 Thanks i figured it would bolt in fine i was worried bout the electrics cause i knew the 3.5 cars were a bit odd but with you and guy with an intrige in his sig givin the ok im gonna buy it 67k miles in a running driving car(so i can test it myself and 50 bucks cash or trade car has a cracked head it will all bolt up no problem, same bellhousing pattern between them. working 100% as intended.... maybe. with the 3.29 version, pretty good chance of it being acceptable, to say the least, especially without any calibration tweaking. Quote
