97oldscutlas Posted August 16, 2013 Report Posted August 16, 2013 Looks like its the ever elusive timing chain cover leak directly below the rear head gasket.. same old question guys.. please chime in Timing cover users say remove oil pan http://www.gminsidenews.com/forums/f53/96-pontiac-3-1-timing-cover-leak-82967/ users say do not remove oil pan http://www.hotrodders.com/forum/gm-1995-98-3-1l-timing-cover-water-leak-issue-163617.html http://www.gmforum.com/oldsmobile-171/front-cover-gasket-replacement-304245/ http://www.chevytalk.org/fusionbb/showtopic.php?tid/289398/ Not sure if I'm gonna do the oil pan or not.. certainly can't hurt since it'll go bad sooner or later.. What has been your experience??? Quote
19Cutlass94 Posted August 16, 2013 Report Posted August 16, 2013 No, you dont need to remove the oil pan. remove the crank pulley, ( 18mm bolt ) then remove all the timing cover bolts, and pull it off. make sure you drian the coolant from the block first using the two drains in front and rear of the block, or both sides depending on how your looking at it. If you dont do that first, youll get alot of coolant going into the oil pan. Clean the block and the timing cover up, inspect the seal, then reassemble. Quote
