l67ss Posted August 15, 2013 Report Posted August 15, 2013 Will a 4t65 still go into all four gears with everything but the speed sensor unplugged if u manually shift it? Quote
RobertISaar Posted August 15, 2013 Report Posted August 15, 2013 no. just like the 4T60E, with the shifter in 4th or 3rd, you'll be in 3rd gear. with it in 2nd or 1st, you'll be in 2nd gear. those are your only two gears where the manual shaft can override the shift solenoids. you'll also be at full line pressure, so expect some odd things to happen. Quote
l67ss Posted August 15, 2013 Author Report Posted August 15, 2013 Ill jus wait til i do the engine swap Quote
l67ss Posted October 29, 2013 Author Report Posted October 29, 2013 Does anyone have the pinouts for a 2000-01 lumina Thanks Quote
RobertISaar Posted October 29, 2013 Report Posted October 29, 2013 http://imgur.com/to2tisv,upywKID 01, not that i think it makes any difference. Quote
l67ss Posted October 29, 2013 Author Report Posted October 29, 2013 I can get either one so itll work thanks man http://imgur.com/to2tisv,upywKID 01, not that i think it makes any difference. Quote
l67ss Posted October 29, 2013 Author Report Posted October 29, 2013 One more question, i can use the pcm from the 01 in my 97 without screwing with the passkey, right? Just wanted to make sure. Quote
RobertISaar Posted October 30, 2013 Report Posted October 30, 2013 should. the passkey module needs to match the key, but the PCM only cares about seeing the 50Hz signal coming from the passkey module. Quote
l67ss Posted October 30, 2013 Author Report Posted October 30, 2013 Kool thanks man should. the passkey module needs to match the key, but the PCM only cares about seeing the 50Hz signal coming from the passkey module. Quote
l67ss Posted November 19, 2013 Author Report Posted November 19, 2013 Just curious, how will swapping to a 4t65 and large port 3.1 pcm affect my cars performance? Currently running a 2002 3.4 longblock, small port 3.1 intake, 3.4 tb and a 1997 4t60. Gonna swap it whether it helps or hinders performance, just wondering. Thanks Quote
l67ss Posted November 19, 2013 Author Report Posted November 19, 2013 Donor car for 4t65 is a 2001 monte ss, donor for pcm is a 2000 lumina Just curious, how will swapping to a 4t65 and large port 3.1 pcm affect my cars performance? Currently running a 2002 3.4 longblock, small port 3.1 intake, 3.4 tb and a 1997 4t60. Gonna swap it whether it helps or hinders performance, just wondering. Thanks Quote
l67ss Posted February 21, 2014 Author Report Posted February 21, 2014 Just a heads up for anyone wanting a 4t65 behind their 3x00, you just need pcm and harnes from a 2000-01 lumina, injectors 2000+, tranny lines and cvs. L36 tq converters WILL bolt to a 3x00 btw. C100 pinout link on this page Quote
Imp558 Posted February 22, 2014 Report Posted February 22, 2014 The L67 converter has different balance weights on it. Probably not a good thing to run the L36 one. Quote
