transmission harness grounds?
Where are the locations of the solenoid ground's on the 4t60e or transmission grounds ? Please and thanks
the shift solenoids are grounded through the PCM(the solenoids have a constant +12V and the PCM switches their ground to activate them), which is grounded to the engine/transmission, which eventually makes it back to the battery negative terminal.
