Quick question for you guys.
I could get a set of KYB Exel-G front strut assembliealmost brand new.. i think around 5000k's km for a 120$ both from a 2nd gen W-Body.
Do theses fit my Buick? If so they are sold.
So far no one has conquered the balljoint part of it.
Its the first I ever heard of that. Which would moderately surprise me since its a totally different setup on those cars.
Havnt tried it so idont kno for sure saw it on a thread about coilovers they sed its an insert strut that has more availability b worth checkin n2 :)
  • 2 weeks later...
You can also jus shorten a gen two tie rod :)
That's an easy one. Just use Bonneville outer tie rod ends.
Wouldn't you loose precious precious threads that way? Its only threaded at the end isn't it?
Theres about three inches of thread on a gen 2 you only use about an inch
Well then I suppose that would work as well. It just might be tricky to cut the ends straight. Are you currently swapping over to the gen 2 knuckles?
