chumychew Posted August 5, 2013 Report Posted August 5, 2013 Hello. I have a 1993 Cutlass Supreme Sedan 3.1 with approx. 70,000 miles. About 2 months ago the auto door locks stopped working - they would not lock from the switch on the door or when you put the car in drive/reverse. The switch on the door did however open the door locks Although that seems to be failing too at times). I replaced the chime/door lock module (located under the dash on the driver's side) with a used one purchased on eBay (I am assuming for purposes of this discussion that such purchased relay is correct and working) and no luck. I also took the car to the local GM dealer who after $150 in charges advised they could not find the problem. They advised they believe there is a short in the system (I am suspicious of that conclusion). While I know many people would be happy to have the auto door lock feature inoperable, I want the car to be in original working condition. If anyone has had this problem or has thoughts thereon (or even where I may find the the correct Lectron Prod. chime relay module specifically for a 1993 Cutlass), your thoughts would be very much appreciated. Thanks again. Rob Quote
crazyd Posted August 8, 2013 Report Posted August 8, 2013 Look thru your local junkyards for similar 1stgen W-bodies, they should have a few. I'd get the switch from the door and the relay/circuit breaker from the electrical center under the dash, behind the passenger lower kickpanel and try those out. Should only cost you a couple bucks for those parts. Quote
