gp 3.1 exhaust swap. help?
I have an 02 grand Prix se with a 3.1 v6 is it possible to take the dual exhaust from the cat back from an 03 grand Prix with a 3.8 non supercharged and put it on my car? Andwill it sound any ddifferent?
Youll need the d side hanger for the other muffler itll sound about like a v6 95 camaro :) ive got 2002 gp gt exhaust on my 97 monte ls youll pick up sum mpgs and sum torque :)
Thanks for the help. I work at a junk yard so where would be the best location to cut the exhaust off at?
Probably right after the front tires, before or after the CAT. If you have emissions in your state, you may need to keep the cat. I know my car if I run the dual exhaust il need to wrap the left side where it will sit up next to the fuel filter (just my pref) and make it to where I can get to it.
or right where it Ys it's up to you. I plan on deleting my cat and spacing the O2 sensor.
I cut mine at the y cause mines a monte therefor shorter :) the exhaust may hav a flange on the cat so no need to weld :)
