yorxs Posted July 30, 2013 Report Posted July 30, 2013 I'm familiar with replacing A/C compressors, so I'm not asking how hard it is to replace a compressor, but how hard is it on an LQ1. I've replaced the power steering and waterpump and found access to be very easy, but I have heard the alternator is a tough one. How is the access on the compressor compare? Anyone know of a good writeup? Quote
Crazy K Posted July 30, 2013 Report Posted July 30, 2013 Clearance is achieved by removing passenger side fan. use a small flat head to pry the fan plug off, unless your fan has an auxilary pigtail (aka extension cord). two 10mm bolts hold the fan on. set it aside and don;t loose the bolts. compressor is held on the front by three 13mm bolts, two 10mm on the back, plus the piping (13mm nut) installation is pretty straight forward, but you might find it easy to loosen the rear bracket which is held to the block. good enough quick guide? Quote
yorxs Posted July 31, 2013 Author Report Posted July 31, 2013 Thanks, sounds very straight forward. Quote
ManicMechanic Posted August 1, 2013 Report Posted August 1, 2013 Helluva lot easier than replacing the alternator. Quote
yorxs Posted August 5, 2013 Author Report Posted August 5, 2013 (edited) Also, does this system use a fixed or variable inline orifice tube, is it dependent on if you have a variable compressor? Should I be looking for it between the condensor and the accumulator? Edited August 5, 2013 by yorxs Quote
crazyd Posted August 8, 2013 Report Posted August 8, 2013 It's a variable-displacement compressor. The orifice tube is on the firewall side of the high pressure fitting, there is a coupling just a bit downstream of it under the cruise servo. Quote
