Bout to install an 01 regal rack into my 97 monte(faster ratio anyone hav the schematics for the magnasteer
yeah, i would be somewhat amazed if it will all bolt up to the 1st gen front end.
I went nuts trying to find the correct rack for my '92--'93 Lumina Euro 3.4. I have absolutely no idea where to source them. NAPA, AC-Delco, etc. show only the slower-ratio (more turns lock-to-lock) units.
Itll fit u just gotta change the outer tie rod ends im also using a u joint off a 2000 lumina gonna go to the jy today to double check fitment tho
I never knew that. learn something new everyday. will the lines fit up the same?
now as for the wiring I do not know how that works at all.
something, something, magnetic donut.
somebody post in this thread tomorrow, i don't feel like uploading a diagram tonight.
I know the gen 2 magnasteer will steer fine wo bein hooked up jus wanna wire it cause i thot itd b cool :)
you sure? i tested it last night and it worked then. opened it now, still works. Ctrl+F5 to force a redownload, still functional.
imgur blocked for you for some reason?
Thats highly possible im on crappy wifi ill get my buddy to try and dl it for me in any event thanks for the help :)
Rack is n!!! I had to "persuade" the ps lines to fit but otherwise it was drop in really responsive now :)
