2009 Chevrolet Lumina LTZ random acceleration problem and Cruise Control
I have a 2009 Lumina LTZ 3.6L with 2 main problems -
1. The acceleration suddenly stops randomly when my feet is on the pedal. This happens between any speed, 0-60 or 60-100KMPH. It happens completely random to me which is why I fail to explain it to any technician. The tech said there is no error code so he cannot do anything. I have to raise my feet off the pedal and give it another go to engage acceleration.
Its not like the acceleration doesn't work at all.. .maybe it goes 0-60 or 70 and then stops revving. I will have to give it another go to continue. Any idea what this could be?
2. My cruise control does not engage. The visual indicator says Cruise On, but it does not say Cruise Active. Earlier, it used to say Cruise Active but it used to dis-engage 5-10 minutes later. Now it doesn't go active at all. The tech again said.. no error code for this so cannot tell.
They usually recommend some random part to be replaced but they are not completely sure if that would do the fix and result in a hefty bill. Any insight on these problems could help me a lot. Thanks in advance.
Uhhh what country are you in??
Problem with drive by wire?
Troll???
Well if he has a 09 lumina he would be in the Middle East as they are sold by Chevrolet Arabia. They are the same platform as a g8 so you would be better off checking G8 forums or Holden forums
Sent from my iPhone using Tapatalk
