19Cutlass94 Posted July 15, 2013 Report Posted July 15, 2013 (edited) First, can a Mod please move this to the FAQ section. Thanks. For anyone that has a 5speed W-body, we all know about the situation with shift cables. They are hard to come by and condition is unknown. Well fortunately, if your looking for one, your problem has been solved. This is the cable that I had in the group buy: This cable is rated for 215lbs push and 620lbs pull. The length is the same as the stock cable. It is physically bigger around than the stock cable, so you will have to modify the body grommets for this to fit. Now how do you get one? You will need to contact this company: http://www.hydradynellc.com/ Here is a list of their locations with contact information to see which is closest to your location: http://www.hydradynellc.com/locations/index.php Now that you know where to look, heres the info youll need to tell them. The part number for this cable is: 173-M-TT-2-59.75 Here is the e-mail from 01/08/2013 Hello Jason, your price for the 173-M-TT-2-59.75, would be $ 133.94 each, up to 10 units, over 10, would be $ 110.92 each, plus freight and any applicable taxes. Please allow 3-4 days to build, test and ship.Thanks Since this was from 01/08/2013, expect prices to go up. Now the good thing about this cable is the end hiem joints can be changed. Shift cable for a 282/284, select cable for 282/284. If you have a different platform car, the last number ( 59.75" ) is the cable length. The J,N, etc platform cars use a shorter cable. Just measure your cable and give them that measurement instead of the 59.75" Now the bad part about this cable, since it is adjustable, youll need to mess with the adjustment, to make the shifts perfect/make it go into all the gears all the way. This will take a little time. Also, the end hiem joints are not perfect and might need some working with to make them fit. Everybody with a 282/284 equiped W-body, no need to worry about old shift cables. This will be the last one you buy. If anyone has any questions or wants more information, PM me. -Jason Edited July 15, 2013 by 19Cutlass94 Quote
carkhz316 Posted July 15, 2013 Report Posted July 15, 2013 I'll let you post or edit if you don't want this info as a separate post 19Cutlass94, but I contacted the company in the link and they are selling those cables for ~$75 + shipping right now. I just broke my shift cable on a test drive last night and was bummed at first but now relieved that we can get these for an affordable price. So jump on them people so you never have to replace your cable again! Quote
19Cutlass94 Posted July 28, 2013 Author Report Posted July 28, 2013 Well as it was brought to my attention, these cables dont come with the end hiem joints. However they can be had for around $15 ea. Guess nobody reads my threads or wants to move this at all.... Quote
carkhz316 Posted July 29, 2013 Report Posted July 29, 2013 I do! To add, the "Heim" style end joints (I was told heim was a brand name apparently) that work with these cables and fit perfectly are under the Dorman line (same as parts store stuff) part number #116-102 Quote
l67ss Posted January 19, 2015 Report Posted January 19, 2015 I was right I did read this. And I was collecting parts for my 3800 swap lol Quote
l67ss Posted January 20, 2015 Report Posted January 20, 2015 You were right about what? I read this while deep in another project therefore it didnt stick Quote
Psych0matt Posted January 20, 2015 Report Posted January 20, 2015 bookmarked and added to my post-tax-refund list of things to buy Quote
